Computer monitor goes black :(
kennysarmy
Can anyone help???
On Mon 09/05/2011 18:39:56 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050911-22510-01.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl+0x8CC26)
Bugcheck code: 0x116 (0xFFFFFFFF87D32510, 0xFFFFFFFF931E6258, 0xFFFFFFFFC000009A, 0x4)
Error: VIDEO_TDR_ERROR
file path: C:\Windows\system32\drivers\dxgkrnl.sys
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: DirectX Graphics Kernel
Bug check description: This indicates that an attempt to reset the display driver and recover from a timeout failed.
The crash took place in a standard Microsoft module. Your system configuration may be incorrect. Possibly this problem is caused by another driver on your system which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: dxgkrnl.sys (dxgkrnl!TdrCreateRecoveryContext+0x1F2)
On Mon 02/05/2011 10:29:47 GMT your computer crashed
crash dump file: C:\Windows\Minidump\050211-29296-01.dmp
This was probably caused by the following module: ntkrnlpa.exe (nt+0xDCDFC)
Bugcheck code: 0x116 (0xFFFFFFFF861D0510, 0xFFFFFFFF931E4258, 0xFFFFFFFFC000009A, 0x4)
file path: C:\Windows\system32\ntkrnlpa.exe
description: NT Kernel & System
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
On Mon 25/04/2011 11:32:41 GMT your computer crashed
crash dump file: C:\Windows\Minidump\042511-29031-01.dmp
Bugcheck code: 0x116 (0xFFFFFFFF88124008, 0xFFFFFFFF931E1258, 0xFFFFFFFFC000009A, 0x4)
kennysarmy
Just put the latest NVIDIA drivers on
& Win 7 SP1
Will monitor...
Running ASUS SmartDoctor and GPU temps at idle are about 45-50 ded F
AML
No offense but this is a very one sided discussion....:D
You seem to know what your doing. If you re-installed windows and it still doesnt work, then it could be a hardware problem.
My old GPU had a problem and it would over heat and shut down.
Got a new card since then and never had a problem.
Hisense U7H TV and T+A Solitaire T headphone reviews, AV/HiFi news plus, what is screen uniformity?
