computer monitor as tv ??
rob virgo
Joined
Nov 27, 2004
Messages
218
Reaction score
Points
75
can you use a computer lcd monitor as a tv monitor rigged to change source to feed vga to screen.
just add speakers
may be a silly question but i dont mind be made look a fool.
cheers
rob
the only stupid question is the unasked one.....lol
Easy answer is that yes you can do as you describe but you will need a product such as:
http://www.lektropacks.com/view_item.php?product=46&&category=13
This sorts out the issues of scaling and synching for the display.
It should be said though that just because it can be done doesn't mean it should be done!!! Given the price and limitations of the adaptor devices you would be much better with a LCD TV with good support for PC resolutions.
Neil
TV Buying Guide - Which TV Is Best For You?
Back
