Computer hard drive and MP3
Discussion in 'Headphones, Earphones & Portable Music' started by bluebs, Aug 9, 2005.
  1. bluebs
    bluebs
    Aug 9, 2005
    5
    It's about time I get an Mp3 player so have decided to get hold of a rio carbon.
    I have one question which is undoubtedly going to sound a bit stupid - I have a work and home laptop, work one is win 98 so ruled out for connecting up to the player, home one is win 2000 but only 4gb hard drive. Am i going to be able to fill the 5gb player using this computer? - i was imagining encoding, transferring and deleting from the hd a few times or will the player try to match up with the computer drive and hence erase what is on it and not the computer.
    Also will be getting a fm transmitter (not for use in uk obviously tho) - is there anything better than the belkin tunecast 2 (sounds like it's a decent bet and i will want a car cig plug)
    Thanks in advance for the help
  2. shadowritten
    shadowritten
    Think there's a decent FM transmitter on the Proporta site ...
    Don't think the Carbon syncs with the PC in the way you describe, but could be wrong.
  3. Uridium
    Uridium
    Jan 29, 2005
    14,415
    North West Leicestershire
    +1,858
    for the sake of £40 you can get a 120-160Gb hard disk from Ebuyer or somewhere, just stick it in your PC as a Slave disk and it wil save you a hell of a lot of grief and hassle
  4. shadowritten
    shadowritten
    Or if, for whatever reason, you don't have the luxury of expansion slots, get yourself a high capacity external hard drive and just upgrade your USB to 2.0.
