Computer DVD and video
Discussion in 'Desktop & Laptop Computers Forum' started by AlanB1, Sep 8, 2001.
  1. AlanB1
    AlanB1
    I am considering using a computer DVD drive and the "all in wonder" video card as a home theatre source. My feeling is the video is better using a VGA of DVI input compared to component or s-video. The advantages of the computer are the ability to use the VGA or DVI input to the projector, but I'm worried that the quality, both video and audio, may not be what I can get from a good progressive scan consumer DVD player. Are progressive scan computer DVDs available?
    I'm new to this and would like some advice on the best set up. Help.
    ...Alan
  2. Arthur.S
    Arthur.S
    Alan, this isn't a topic I'm very 'up' on I'm afraid. I think you're in the wrong place anyway. Try the HTPC forum on this site, or as you're from Canada, wouldn't the AVS forum be better for you?
    Good luck,
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,771
    7
    2
    167
    Birmingham, UK
    +10,676
    Yeah, why on earth is this in the Video Projectors forum?!<br />Moving it to HCPCs.
