computer crisis!
Discussion in 'General Chat' started by blue max, Apr 16, 2016.
Tags:
  1. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    Sorry guys, bit desperate to get my son's laptop working again as he needs some files off it to revise for an exam next week. I'm a mac man and this is windows 10 :eek:
    Basically it is in an endless loop of trying to fix itself and failing. I can't get it to boot up at all. Tried every option I can think of or google.
    I've reseated the hard drive and ram and it still can't fix itself.
    I've run checks on the ram/hard drive and all pass I think.
    I got to command prompt and ran something like fsc /checknow (from memory) which seemed to run, but then said it couldn't perform the requested action or something.
    Any simple pointers would be so much appreciated :smashin:
  2. mjn
    mjn
    May 24, 2001
    23,545
    Herts, England
    +11,951
    If data recovery is vital. Put the hard drive into an external USB caddy and then plug into working laptop. Retrieve files.
  3. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    Absolutely I would. If I had an external caddy and another pc :D
    I'm hoping to find out what needs to happen to get this working again really.
  4. mjn
    mjn
    May 24, 2001
    23,545
    Herts, England
    +11,951
    You got a Mac, its got Usb? So you're just a caddy away from recovering your data.
    I suppose it all depends on how important the data is.......
  5. nheather
    nheather
    Oct 6, 2004
    18,866
    167
    Horsham, West Sussex
    +8,808
    My PC has an eSata interface. If you know someone with similar then just plug the drive into it.
    Failing that if you know someone who builds their own PCs you could ask a favour - connect the disk onto a spare SATA - the MoBo will have spare sockets and he is bound to have a spare SATA lead.
    Cheers,
    Nigel
  6. BB3Lions
    BB3Lions
    Apr 24, 2009
    14,511
    3
    +6,111
  7. balidey
    balidey
    Jan 2, 2009
    3,664
    +3,537
    May be a bit involved, but you can install Ubuntu onto a memory stick. Its an operating system that you can plug into the PC. You then get two options, install or trial.
    Use trial and then you will be able to scan the hard drive for all the files you need, save them onto the memory stick. I've done this a couple of times and got me info off of a 'broken' windows PC.
  8. razer1
    razer1
    Jan 5, 2011
    918
    46
    Leicester
    +155
    if you've got a seagate goflex hdd about, the connector adapters work on 2.5" hdd's perfectly. Ive had to do this several times in the past.
    This is what you need!
  9. nheather
    nheather
    Oct 6, 2004
    18,866
    167
    +8,808
    Good idea.
    Cheers,
    Nigel
  10. imightbewrong
    imightbewrong
    Dec 6, 2005
    53,051
    167
    Romford-ish
    +33,570
    To get the silly suggestion out the way - have you tried booting to safe mode? How far into boot does it get before restarting?
    • Like Like x 1
    • Agree Agree x 1
    • List
  11. simonlewis
    simonlewis
    Jul 31, 2014
    4,450
    stockport
    +1,644
    Agree with IMBW press F8 continuously and then boot in safe mode.
  12. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,846
    +7,096
    I don't think Macs can read NTFS?, which is what a system drive is likely to be formatted as.
    F8 was disabled in W8 & is also absent from W10.
    @blue max If you don't have any success & can get it to St James's Park tube tomorrow, I should at least be able to get the required data off it. Drop me a PM if need be.
    • Like Like x 2
    • Thanks Thanks x 1
    • List
  13. imightbewrong
    imightbewrong
    Dec 6, 2005
    53,051
    167
    Romford-ish
    +33,570
  14. BT Bob
    BT Bob
    Nov 22, 2006
    2,358
    116
    Cardiff
    +1,110
    I believe MACs can read NTFS, but can't natively write to NTFS partitions. You can use a third-party application to enable this.
  15. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,846
    +7,096
    That being the case then sourcing a USB caddy in London shouldn't be a problem, even on a Sunday.
  16. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    Hitting f4 goes into automatic repair and then back to the loop unfortunately.
  17. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    Thanks for all the suggestions guys, Everything just ends up at preparing automatic repair.
    Sourcing a caddy is a temporary fix, but I need to get his computer working again really. He uses it for school. The hard drive is an HP ssd which was newly fitted when I purchased the computer on the forum here. He had ordered it from the States I seem to remember, so not easy to get hold of.
    I also really need to diagnose the problem ideally.
  18. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,846
    +7,096
    Get the data off & you can do a fresh install.
  19. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    I have pm'd you and if you are still able to meet me there, I'd like to take you up on your kind offer.
    Thank you.
    Graham
  20. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    Added some pics as its not a standard sata drive I think.
    Drive underneath is a regular sata drive.
  21. nheather
    nheather
    Oct 6, 2004
    18,866
    167
    +8,808
    The 'temporary fixes' were suggested because in your OP the priority seemed to be getting files off the drive so your son can revise for an exam next week.
    Given the importance of that I would have thought a caddy would have been a small price to pay.
    As for long term fix, you are most likely looking at a re-install.
    Cheers,
    Nigel
    • Like Like x 1
    • Agree Agree x 1
    • List
  22. razer1
    razer1
    Jan 5, 2011
    918
    46
    Leicester
    +155
    Looks like standard 2.5" drive to me from them pics.
  23. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,846
    +7,096
  24. razer1
    razer1
    Jan 5, 2011
    918
    46
    Leicester
    +155
    Oops! hadnt spotted that!
    Was on my phone when I looked at the pics lol....
  25. DVD-Man
    DVD-Man
    Jul 24, 2004
    8,580
    Ayrshire, Scotland
    +1,932
    SSD still has same SATA connections.
    Sent from mTalk
  26. hippo99
    hippo99
    Feb 29, 2008
    16,210
    163
    +9,300
    Don't SSDs usually come with some plastic adapters so you can use it with 2.5" & 3.5" bays? They're not even essential but provide a bit of 'padding' to fill out the difference in size.
  27. nheather
    nheather
    Oct 6, 2004
    18,866
    167
    +8,808
    Not always - my Samsung Evo didn't - but they are readily available and cheap.
    But to improve the airflow in my HTPC case I removed the whole disk cage framework and simply velcro'ed my SSD onto the side of the case.
    Cheers,
    Nigel
  28. phillyd1981
    phillyd1981
    Dec 10, 2006
    2,566
    +1,473
    If you have access to a different pc you can make a usb or dvd windows 10 install disc put it in your son's laptop, boot into the disc after selecting the language thire is a option to repair this pc which will scan and repair any startup issues.
    The windows 10 creation tool is in the link below when you run the soft ware just ensure the version of windows 10 you select in the tools options match your laptops version (32 or 64bit and home/pro) or you can use the install media to reinstall windows.
    Windows 10
  29. blue max
    blue max
    Apr 12, 2006
    12,909
    London
    +4,273
    Thanks everyone. Tried to buy a micro sata to usb cable and nowhere in London stocks them.
    He's taking it to the school IT department tomorrow to see if they can help.
    I tried!
  30. nheather
    nheather
    Oct 6, 2004
    18,866
    167
    +8,808
    Did you try downloading a USB version on Linux.
    Download and create a linux usb stick.
    Boot laptop from usb
    Copy files from hard disk to usb
    Cheers,
    Nigel
