compression?
Discussion in 'Desktop & Laptop Computers Forum' started by jayr6666, Mar 23, 2006.
  1. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    hello all,
    can i compress dvd files that are over 4.5g to fit on dvds that are actually 4.5g?all the software i have{nero]has no facility for compression.anyhelp would be gratefully recieved.thanks.jay.
  2. dannyg81
    dannyg81
    Nov 23, 2005
    382
    +9
    There's loads of software that will do this... including Nero 7 Ultimate edition. Others like DVD Shrink, DVD Santa, DVD Clone etc... all with varying degrees of quality. Try a few and see which is the best for you.
  3. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    cheers,danny,
    i already have dvdclone but it wont let me copy commercial discs.any help?
  4. dannyg81
    dannyg81
    Nov 23, 2005
    382
    +9
    Download something called DVD Region+CSS Free. That should sort you out. You can only download free trial versions but I'll leave you to figure out how to work around that one. :D
  5. jayr6666
    jayr6666
    Feb 26, 2006
    519
    newcastle
    +18
    cheers,danny.
    muchappreciated.
  6. throwit
    throwit
    Jan 30, 2006
    521
    +14
    i've got that dvdregion+css free...does the business, but now and again you'll need to update it
    i also use 1click dvd copy, this works for the compression/copying/burning bit, but it can be moody - it's best to make a 4.5gig copy to hard drive and if you watch it at 32x speed (only takes a couple of minutes) and it smoothly progresses right through without locking up, then you should be able to burn a decent copy to dvd...1 click can also handle copying and burning to dual layer (if you do this, dvd+r seems more reliable than dvd-r)
  7. GCDB
    GCDB
    Sep 23, 2004
    321
    Wrexham
    Dvd shrink is great with nero,and free to download(small file if i remember as well).JUst type dvdshrink in google.
