Compression...
Discussion in 'AV Receivers & Amplifiers' started by lowrider, Nov 24, 2003.
  1. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I said before I enjoyed the TAG more with classical music, but the Krell is better with everything else...
    Well, the other day I remembered that the Krell has 3 compression settings: MAX, (no compression), Normal and Night, (high compression for when you dont want to bother your neighbours)...
    So I tried Normal with classical music and, voila, more coherence, more like live concerts...
    Interesting, what do you think... :confused:
  2. S H A D O
    S H A D O
    Mar 16, 2001
    10,279
    United Kingdom
    +1,563
    What mode are you listening to music in?
  3. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    I always used MAX, no compression makes sence to me, but now I have to admit a bit of compression sounds nicer with classical music, so I use Normal for it... :eek:
  4. S H A D O
    S H A D O
    Mar 16, 2001
    10,279
    United Kingdom
    +1,563
    Sorry, I mean't mode as in Dolby PL2, Stereo etc? I can only think that it works like Dolby's Dynamic Range Control and at lower levels makes it easier to hear the finer details and ambient sounds.
  5. lowrider
    lowrider
    Sep 29, 2003
    676
    Riga, Latvia
    OK, it does the same with DPLII or stereo or whatever...
