Compressing recordings - recorder or PC?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Nelviticus, Nov 7, 2005.
  1. Nelviticus
    Nelviticus
    Jun 21, 2003
    474
    Hitchin
    +69
    I've been recording 'Lost' on my Panasonic E95 at best quality and each episode takes up about 2.4GB. I want to burn the series (on my PC) to double-layer discs, fitting six episodes to a disc. Double-layer DVDs are 8.5GB so I need to compress the episodes by about 50%.
    I have two ways of doing this: I can either get the Panny to re-encode the episodes when it transfers them to my DVD-RAM discs, or I can transfer them as they are then compress them on the PC.
    Does anyone have any idea which method will result in the best quality? If I do it on the PC I'll make an over-sized disc image using TMPGEnc DVD Author, then re-encode it using Nero Recode. I could just try both methods and see which works best but firstly either method will take at least a couple of evenings and secondly I don't want to waste a double-layer disc! If someone has experimented with this before I'd be grateful if you could share your experience.
    Regards
    Nelviticus
  2. smallmanongn
    smallmanongn
    Why record them in good quality and then compress them 50%,seems a bit silly to me.
    If you compress them on a PC you will see a difference,dont know about the Panny but there has to be some loss somewhere to get them to fit.
  3. nwgarratt
    nwgarratt
    May 5, 2002
    27,863
    +3,196
    I recorded Lost at SP quality and can fit three episodes on a single layer without compressing.
    I do compress on the computer and get better results than recording at lower quality. At 50% I would re-encode rather than compress as the quality is a lot higher. I would look at downloading the free version of DVD Rebuilder 0.96 and use a encoder such as HCE or Quenc. You can download DVD-RB and all the encoders will be installed at the same time. However, it takes a lot longer to re-encode.
    If I only need to compress a small amount (up to 20%), I just use DVD Shrink.
    DVD Rebuilder 0.96 Installer
  4. Nelviticus
    Nelviticus
    Jun 21, 2003
    474
    Hitchin
    +69
    Why record them at good quality? Because it seemed like a good idea at the time!
    Cheers NWGarratt, I will check out those apps.
    Regards
    Nelviticus
