Composite video cable - help needed
calypso
Joined
Feb 3, 2003
Messages
32
Reaction score
Points
14
Location
Switzerland
I am currently using my Epson S1 projector connected to my DVD player through the S-Video input.
I would like to use the composite video outputs (3 RCA sockets on my DVD player) but the composite video input on the projector is a 15-pin computer/multimedia socket.
I have looked around local stores but have been unable to find a suitable cable. Epson do make one as an option ($100!!) , but the local dealer does not stock them.
I could make up the cable myself but I need to find out how such a cable would be wired at the 15-pin end.
Grateful for any advice.
Keene definitely do the cable you are after. Why don't you give them a call? Make sure you let them know what model you have as H or V sync can be an issue.
BTW, I assume you mean component video, not composite :) Composite is a single phono connection with the entire video signal going down one cable. As you would expect given no channel separation it's usually crxp.
Thanks VirusKiller.
Yes, I did mean component video.
Grateful if you could let me know how to determine whether I need H or V sync for the Epson S1.
Many thanks,
I'm afraid I don't know. My first port of call would be the manual :rolleyes: but if that's not revealing, I'd simply talk to the people at Keene. I know, for instance, that they made a specific SCART -> RGB conversion cable for the Sanyo Z1. So they may well know what to do for the Epson.
HTH,
Joel
John the component signal has sync on green.
Pin connections on a 15 pin HDD connector for component are
1 red
2 green
3 blue
6 red ground
7 green ground
8 blue ground
hope this helps
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
