composite to S-video?
Discussion in 'Home Cinema Control & Remote Controls' started by richard plumb, May 10, 2003.
  1. richard plumb
    richard plumb
    Jan 27, 2002
    14,340
    Windsor
    +1,026
    I currently have all my av kit set up away from my TV, with a single s-video cable going across the mantlepiece to provide video.
    But I can't watch my VCR.
    It is currently connected to my TiVo, which in turn goes to an RGB-S-video converter.
    Any suggestions on how to get the VCR output on my TV? Is there a composite-s-video converter? If so, how do I get the signal out - my VCR only has one SCART, which is currently used when archiving from TiVo to tape.
    Any suggestions greatly appreciated.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Compoiste to s-video converors can be bought from Maplin for £4.99.
    Not sure how you would get a second feed though, sounds like you need to modify a SCART lead to give a video output. There may well be something like this already available.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Do you have an AV amp with S-vid ins and outs? If so that should up scale any composite inpute into the S-vid out put.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
    This feature is only avilable on certain models, such as the Denon A1SR and 3803.
  5. paiger
    paiger
    I think the new Sony does it too but anyway, I got my converter from http://www.svideotorca.com/rcatosvideo.html
    It's a great device and very well built, feels heavy. Not sure if it's better than the Maplin ones but it turned up in about 3 days from the US!
    I know you can get a scart lead that has a box in it which allows you to take composite signals from it. Seen them at Maplin.
