Hello john R1
If you install a PS2 RGB SCART cable you can daisy chain the PS2 via your Freeview box - and by replacing the PS2 Composite cable with the RGB cable you'll also improve image quality.
As your already using the 'daisy chain' or 'Pass-thru' function on the Freeview for your DVD player you have two options.
01. If your DVD player has two SCART sockets you can form a slightly longer daisy chain - PS2 > DVD > Freeview > TV.
02. If the DVD only has a single SCART Out you can simply add a low cost SCART switcher to your set up - to enable all three source devices to connect to the single Input on your TV.
If you leave the DVD connected to the Freeview all you require is a decent quality Two way SCART switch and wire as follows:
DVD > Freeview > SCART Switch Input 01
PS2 > SCART switch Input 02
SCART switch Output > TV
See
http://www.js-technology.com/produc...id=31&osCsid=ccac9b6660e9ebf8535303c2572d4edb
For best results set your Freeview, DVD, PS2 and TV to RGB.
Best regards
Joe
