I have a component input which I'd like to be able to plug an old composite cable source into.
What's the best way of doing this? They're both analogue signals I think so technically it shouldn't be a problem? I'm probably being hugely naive here.
Audio obviously isn't a problem, however video would be?
Would a simple S-Video to component video converter cable work.
For example Here
So Composite source -> Phono to S-Video Converter -> S-Video to Composite Converter
Please if you have any better suggestions let me know as I'm sure there's bound to be a better way of doing this!
I'm on a budget so ideally I don't want to have to buy an expensive box which converts the signal but if needs must.
Thanks for your time.
Ben
For example Here
Ben
-- As an eBay Associate, AVForums earns from qualifying purchases --
