Composite os SVHS to RGB using cable(s) only?
Discussion in 'Cables & Switches' started by zedzed, Oct 9, 2005.
  1. zedzed
    zedzed
    Jul 12, 2004
    817
    Linlithgow (nr. Edinburgh)
    +13
    Hi all,
    I've got a camcorder (sony HC42) that I'd like to connect to my panny PW7 plasma. The camcorder outputs either composite or s-video.
    My PW7 has a component board (for DVD player), and I use the VGA input for telewest box (via a Js Tech "RGB to VGA" box).
    So ... my question ... can i get a signal (composite or svideo) to my pw7 using cables only?
    (I'm guessing that svideo to RGB scart might be the most likely possibility ... but that's just a pure guess!)
    Zed
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,418
    The Borders
    +2,590
    ZedZed
    Best to install an S-Video Board into your Display - using the S-Video Board with your camcorder you'll get a very decent image.
    Best regards
    Joe
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Composite & S-Video can not be 'converted' to RGB or anything else without hardware conversion. So as Joe suggested, the best way to get the camcorder displayed on your plasma is by getting an S-Video card for the plasma.
    If however you have an AV receiver/processor that does video upconversion then you can use that. Plug the cam via S-Video & the DVD player by component into the receiver and then the receiver into the plasma by component.
    Mark.
  4. zedzed
    zedzed
    Jul 12, 2004
    817
    +13
    Thanks guys.
    The "2 slot" board (which has svideo) seems to be a staggeringly low £65 at digisaurus .... so I'll get that (which gives me another set of components too ... which I'll probably need for xbox 360 :clap: )
    Zed
