Composite or Scart
Discussion in 'Xbox Forums' started by Sulley75, Jul 14, 2005.
  1. Sulley75
    Sulley75
    Jul 28, 2003
    1,189
    Hants
    +134
    Hi fellas,
    We have recently purchased a tv that does progressive scan and takes component leads for xbox. I have always used scart. Will composite improve the picture or is RGB Scart the best?
    Also, has the forums changed? I seem to remember a forum dedicated to online gaming but it seems to have.. gone! I was gonna go there to hopefully find some new gamers around my age (30) without being called old!! lol
    Cheers in advance,
    Gaz.
  2. Pooon
    Pooon
    Dec 26, 2002
    7,354
    Canterbury, Kent
    +944
    i'm pretty sure you meant to say component not composite. and yes using component with progressive scan from a modded xbox with give a much better image than rgb scart
  3. Sulley75
    Sulley75
    Jul 28, 2003
    1,189
    Hants
    +134
    Thanks, and Doh!! I always say composite, bugger!!
    :D
  4. jerkyboy
    jerkyboy
    Its not much better using component with a standard UK Xbox, you need to get it chipped then it will output 480p, 720p and 1080i modes.
    Then the picture quality is much better. In the Hi- DEF modes its mind blowing, makes RGB scart look like "COMPOSITE" !!!
  5. inzaman
    inzaman
    Dec 16, 2002
    7,964
    Derby
    +1,029
    I went straight from composite to progressive component on my projector and i had a :D for weeks. It really is amazing :thumbsup: especially when you get 720p.
