Composite or Component?
Discussion in 'Cables & Switches' started by ikon66, Apr 30, 2005.
  1. ikon66
    ikon66
    Mar 22, 2005
    451
    Tyne & Wear
    +5
    I'm getting a Sony LF1 which has composit or component out which will be the best to connect to my pioneer PDP43xde plasma
    Component I am thinking :rolleyes:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    YES component!!!!! COmposite is the lowest quality and will look rubbish
  3. ikon66
    ikon66
    Mar 22, 2005
    451
    Tyne & Wear
    +5
    cheers HD thought as much
