Composite>Composite or SVid>converted Composite cabling. Which is better?
Discussion in 'Cables & Switches' started by LJ·202, Jul 29, 2004.
  1. LJ·202
    LJ·202
    I' will soon be adding a DTV HTPC to my current AV system and am looking to maximise PQ (naturally!). My setup is as follows:
    BBK AB907KB DVD player - Component, S-Video, Composite outputs
    SD DVT HTPC with Radeon 9x00Pro - S-Video, Composite outputs
    Pioneer VSX-D511 receiver - S-Video, Composite inputs/outputs
    Teac CT-M805SR 80cm TV - Composite, RGB SCART inputs
    I'd prefer to keep the video signal seperated however since consumer level S-Video to RGB converters are non-existant and my receiver only switches video, my connectivity options are S-Video and Composite only. My question is: Can all composite cabling, using HQ leads provide an equal (or better?) PQ as opposed to running S-Video through the receiver and converting it to Composite just prior to the TV?
    TIA for any comment, suggestions, help, etc :thumbsup:
    Cheers,
    Tim
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,468
    Rainham Essex
    +2,477
    Hi LJ·202 and welcome to the forum!
    I would think that you would get no PQ advantage with S-Video if then going through a converter to downgrade the signal to component.
    Saying that though I would be very surprised if your TV does not accept S-Video via at least one of the scart sockets. To find out for sure you need to :rtfm:
    Mark.
  3. LJ·202
    LJ·202
    Thanks for your reply Mark. I suspected as much in regards to converting S-Video to Composite. I had already thouroughly read the manual and indeed confimed with TEAC themselves that our TV definitely does not accept S-Video. I has only two AV inputs, being 1xfront Composite, 1xrear SCART accepting Composite and RGB only.
    Looks like I'll be investing in some high quality composite cabling.
    Cheers.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Never heard of a TEAC TV where are you? See Sweet spot as they DO RGB capture cards also try HTPC forum for more info
  5. LJ·202
    LJ·202
    Haven't heard of Teac? They're a billion dollar Japanese electronics company.
    How will a RBG capture card help me?
    Will look in the HTPC forum. Thanks.
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I don't think you will be happy with composite cabling. S-Video is superior, RGB usually the best (though the difference to S-Video is not that great as from composite to S-Video).
    Knew of TEAC before but I thought they had gone broke!? Nevermind, your best bet will probably be a converter from composite and/or S-Video to RGB.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    I have heard OF TEAC, but not them making a TV only seperates and HiFi's. Sweet spot will allow you to capture TV at highest level and then output it via a top quality graphics card that either out pus component YUV or YPbPR or RGB hence keeping quality top notch.
