Componet to RGB help
Discussion in 'General Chat' started by DrBombay, May 8, 2005.
  1. DrBombay
    DrBombay
    Hi all!
    Help!
    Am dealing with the usual problem of component to rgb.
    Here is the equipment I am dealing with:
    Dish Network HD receiver 811, info, along with product brochure (download pdf) can be found at:
    http://www.dishnetwork.com/content/products/receivers/HD/index.shtml
    Sony Flat Panel PFM-42B1, product brochure with specs can be found at:
    Need to connect receiver to monitor. Receiver has DVI or Componet outs and monitor only has 2 15pin RGB in along with an s-video
    Will the following product work:
    http://store.a2zcable.com/coviad15mto3.html
    Don't have the knowledge to understand the spec sheet above on the monitor.
    However, on monitor under set-up, have the following "input" options:
    input 1 rgb
    input 1 yuv
    input 2 rgb
    input 2 yuv
    video composite
    video y/c
    Any thoughts would be greatly appreciated.
    Will above cable work?
    Do I need to just get a "componet to rgb converter" such as some unit from Viewsonic or such?
    Thanks in advance,
    DrBombay
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,264
    Manchester
    +756
    Since you have USA equipment , you would be better off posting in the USA equivalent of these forums : www.avsforums.com
    Chris Muriel, Manchester, UK
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I think what you need cannot be done passively. This looks as if it was designed just for your purposes.
  4. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    :thumbsup: Just go into the setup menu on the display and set it to YUV, YUV is another name for component video then all you need is a 3 RCA to HD15 lead for component video
  5. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Sorry did'nt bother looking at your links, the cable you suggest should be fine :smashin:
