Components vs scart
Discussion in 'Blu-ray & DVD Players & Recorders' started by iaria, Jan 9, 2004.
  1. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    BTW I have a Pio 565 with components output and rgb scart
    if I can connect some how component out to scart (if there is such converter) will I get better picture by taking advantage of prog scan???
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    unless your display can accept component video no it wont even work in PS or intelaced.
    A *FEW* displays accept component video over scart but check your manual most have dedicated component inputs.
  3. iaria
    iaria
    Dec 7, 2003
    108
    16
    Crawley,West Sussex
    Sorry Hornydragon, maybe I didnt make myself clear
    My display, 32inch philips can't remember what model,doesn't support prog scan, but I thought because components supposed to be better pic quality, somehow by connecting component out put to scart it might give me better picture
  4. mpdox
    mpdox
    Hello iaria.
    I sure hope to receive myself the answer you're looking for...
    I have a pioneer 565-a and a jvc 32x37sue tv... I still regret the decision to not buy a component input tv, since everyone is talking how great it is... Not that I'm unhappy with the image, it's just the wonder/curiosity left.
    Since the component to rgb devices are quite expensive, I wonder if it will be an improvement in quality, for me it will be worth the price.
    Regards.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    unless the manual for your display states it supports component via a scart it will not work
    RGB is fine for 36" displays
  6. Spligsey
    Spligsey
    Jan 16, 2003
    2,072
    UK
    +137
    Some Loewe TV's accept a YUV signal on AV3 socket (SCART)
    My Aconda 9381ZW does.
    I cant think of any others that do.
    Adz
  7. Warpaint
    Warpaint
    Jul 26, 2003
    589
    28
    Edinburgh
    +61
    Philips do not have component compatibitlity through scart.
    RGB interlaced will look as good as component interlaced anyway.
    As far as I know Loewe are the only manufacturers with component inputs on a scart socket (but even they don't look any batter than RGB scart).
  8. eeper
    eeper
    Dec 4, 2002
    61
    UK
    OK, bit confused now.
    I was in Selfridges today and they sold a cable that had component at one end and a scart output. Is this merely going to downgrade the component signal to scart quality or will it retain its quality. Would it make any difference to plug it into an RGB enabled scart? How about the S-video to scart converters.
    The thing is that I've got a Sony DAV system with only component or S-video output. Most of the tvs I see have the S-video port on the front so I'd like to find a way of getting the signal into the back of the tv thru the RGB scart port. Apart from getting a component input tv (still quite hard to find) whats my best option?
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    You are getting confused between video standards eg RGB and cables EG scart, for DAV system S-video is what to use TV's accept S-video on scart 2 and some have a menu otpion to enable it.
  10. eeper
    eeper
    Dec 4, 2002
    61
    UK
    Thanks horny!
    :hiya:
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I must state that *most* TVs accept S-video in one scart normally 2 but not all do so check your manual.
  12. malaga
    malaga
    spligsey: is a real component signal or is transfor to S-VIDEO?????????:confused: :confused: :confused:
