Components cable for PS2
Discussion in 'Playstation Forums' started by Falp, Mar 5, 2005.
  1. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Hi! My Loewe Xelos 32" has component image In one Scart connection.
    What's the best option?
    Buy a PS2 Euro AV cable or a PS component cable + component/Scart adapter?
    Does the PS2 Euro AV cable carry component video?
    Thanks!
  2. Pooon
    Pooon
    Dec 26, 2002
    7,567
    Canterbury, Kent
    +1,219
    Yes the PS2 does carry component video, you can select it in the main menu for the ps2(no disc in drive) Sony make an offical cable whch iirc costs around £15, try here for one Lik Sang
  3. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    and this cable?
  4. Korum
    Korum
    Feb 19, 2005
    4,423
    Stockton-on-Tees
    +713
    No, the Euro AV cable isn't wired for component out, the Sony Europe site sells the official component cable for around £15, I ordered one and recieved it within a few days.
    I've never heard of a Scart connector carrying a component signal on any make of TV before, Have you found anywhere which sells a scart block with component inputs on it, just interested In taking a look at one.
  5. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Look here: http://www.avforums.com/forums/showthread.php?s=&threadid=30746
  6. apang
    apang
  7. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    I'm still using the supllied composite cable... :cool:
    But I think the PS2 RGB cable with the component output selected should work on Loewe TVs... anyone knows :confused:
  8. micks_address
    micks_address
    Nov 29, 2001
    4,671
    83
    Dublin
    +239
    Hi - i have a ps2 component lead for sale in the gaming classifieds for 10 quid if your interested....
  9. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Just bought a cheap 4.10€ RGB PS2 cable for connecting my Loewe Xelos.
    The difference is awesome, and guess what? The component output works too and of course is even better! :thumbsup:
    Loewe Rulez... :D
    Of course the TV only has one component input, but my DVD player best output is Svideo...
  10. apang
    apang
    Good job.
    As I hoped, the Component signal (YCrPr) through a SCART connector is carried on the RGB wires. Thus you just switch the output in the PS2 and the input in the TV as you done and voila.
    I'm going to bag me one of those Ixos cables.
    Cheers,
    andrew
  11. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    :thumbsup:
