Component
Discussion in 'Cable TV & Virgin Media TV' started by mobily, Aug 3, 2006.
  1. mobily
    mobily
    Dec 30, 2003
    505
    Plymouth
    +3
    Hey all,
    I have TV Drive and my television has a component input but is not HD ready. I tried to connect TV Drive to it and the picture was all funny. Do you have to have a HD ready TV to be able to make use of component?
    The way the sesttings are worded would suggest you can't connect component if you have a non HD TV.
    Cheers :thumbsup:
  2. Twilight zone
    Twilight zone
    Jun 9, 2006
    72
    +4
    I have a non HD ready TV (Panasonic 7 series 42" plasma) connected to TV drive through component and it works fine. Although you must make sure that the setting are right. I can only get a picture (and a very good one at that) with the settings at:
    TV display format: Hidef Component
    High definition output fomat: 1080
    Hope this helps
