component vs composite?
Discussion in 'Cables & Switches' started by lutek lobster, Jan 20, 2005.
  1. lutek lobster
    lutek lobster
    Can someone post photos of these two so that I can tell the difference?
    thanks,
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    composite is a single cable usually with a yellow connector on each end
    component video is 3 cables coloured Red Green and Blue
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    componet vastly superior PQ
  4. GreenBars
    GreenBars
    Oct 29, 2004
    631
    Hertfordshire
    +23
    Component:
    [​IMG]
    Composite:
    [​IMG]
  5. insanity
    insanity
    well u learn sumthing new everyday then dont u :)
  6. lutek lobster
    lutek lobster
    Thanks for the above, but I'm now very confused. So if I have red, white and yellow cables (video, audio in/out), what do I have? My Sony DAVs300 has no component, I'm reliably told (by this forum, and indeed sony), so I thought the above set up was composite (but it's not red green blue), but now you say comosite is just one cable - so is there a fifth way after scart, component, composite and s video ?
  7. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    From memory the DAV had a choice of s-video or composite video which will be the yellow connector. The red and white connectors will be for audio.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    red is audio "right" and white is audio "left"
    hence stereo. yellow is video.
