Component Video via dsub on PWD6
Discussion in 'Plasma TVs Forum' started by deadfolk, Jan 6, 2005.
  1. deadfolk
    deadfolk
    Jan 4, 2005
    55
    Hi all,
    I understand that you can get component input via the dsub connector on the Panasonic PWD6. I read somewhere that you need a 5 component input cable.
    Now I'm not really up to speed on this stuff, but that's the one that includes H/V (whatever that is) is it not?
    Here's the question: my DVD has only three component jacks (Pioneer DV656A)...can I use this to connect to the dsub on the PWD6?
  2. coolmp3
    coolmp3
    Dec 27, 2004
    321
    +22
    Hi, deadfolk I have got the PW6 and i am using the Vga(DSUB) port for component. I brought a Good Cad monitor cable which had 5 BNC's RED,GREEN,BLUE and the other two not sure what they are. I cut off the BNC's on the Red,green and blue and bought some nice gold Phonos from Maplin and solered them on. The picture is great. Hope this help.
    Chris :smashin:
  3. deadfolk
    deadfolk
    Jan 4, 2005
    55
    Thanks for the reply Chris.
    So you're only using two of the five connectors, is that right?
  4. coolmp3
    coolmp3
    Dec 27, 2004
    321
    +22
    HI, No i am using 3 out of the 5. In use are the RED,GREEN and BLUE cables. The other two are not used. Remember to set your display on the plasma menu for the vga port to component or you will just get a gleen picture only.
    Chris
  5. deadfolk
    deadfolk
    Jan 4, 2005
    55
    D'oh! :suicide:
    I meant three, believe it or not. That's excellent news - thanks.
    (I must have typing dyslexia today - I even orignally typed two instead of three again in this post. I need to sleep!)
