Component Video to Plasma
Discussion in 'Plasma TVs Forum' started by FCP FAN, Nov 14, 2003.
  1. FCP FAN
    FCP FAN
    Hi all :)
    Just have a quick question:
    Im thinking in buying a plasma (Panasonic Hi-def Commercial version),
    and there are 2 types of component video boards available:
    with regular RCA plugs and one with BNC plugs on it.
    So: is there any difference in video quality when using BNC/RCA
    plugs (with quality cables, Nordost or similar), since i will connect
    a progressive DVD player with RCA plugs and would have to use a hybrid cable (RCA plugs in one end and BNC on the other).
    Just wondering :confused:
    Thanks in advance.
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    RCA to BNC is marginally better than RCA to RCA. BNCs all round is the best. This is in general but usually very reliable guide, as I haven't seen the new pannies
  3. FCP FAN
    FCP FAN
    Beekeeper:
    The main reason i ask this is because i already have a quality component cable with RCA plugs (Audioquest Cinemaquest YIQ-2) and the plasma supplier just have in stock the BNC plugs board for the moment.
    So maybe a RCA-->BNC cable its an option but for the moment im not certain if its the right move.
    The BNC is maiginally better? in picture quality? or just in connectivity (its a better plug that remains in place after atached) since with RCA plugs sometimes with time they get a little loose.
