Component video PS2 to Philips LCD
Discussion in 'LCD & LED LCD TVs' started by chrisc, Dec 3, 2004.
  1. chrisc
    chrisc
    Hi all
    Just wondered if anyone has experience of this. I bought an Ixos XPP04 component video cable to connect my PS2 to my Philips LCD TV (30PF9975). Set the PS2 to output component video (Y, CB/PB, CR/PR), and connected everything up, but no picture! In the instructions for the TV, it says that it can take component in from a DVD, but only lists (Y, Pb, Br). I've no idea what this really means, or if this could be the problem. Does anyone know why I'm not getting a picture? Could I have missed something obvious?
    Thanks in advance
    Chris
  2. cR4cKF0x 5TevE
    cR4cKF0x 5TevE
    Sep 7, 2004
    2,103
    St Merryn
    +322
    The 30PF9975 only accepts progressive scan component inputs (576p, 720p and 1080i are listed in the manual, though my Marantz DV4300 now talks to it outputing 480p?!).
    I'm not a PS2 owner, so don't know whether it will output progressive scan, if not, you will have to revert to RGB scart.
    Hope this helps.
  3. Binternet
    Binternet
    Oct 30, 2004
    190
    Sunderland/Newcastle
    What is the model number of the PS2, only the newer ones support progressive scan. SCPH5000 and above will be fine.
  4. chrisc
    chrisc
    Thanks for the replies...
    It's the SCPH-70004 (i.e., the new, thin model). I managed to get an image by using a Region 1 DVD, switching on progressive scan on the PS2 DVD player, and playing that DVD - unfortunately though, that doesn't really help me since the PS2 only gives an image playing that one DVD (ie., nothing from R2 DVDs or games, or just when switching on the PS2).
    Hmmmmm... :confused:
  5. Binternet
    Binternet
    Oct 30, 2004
    190
    Ahh, I dont think the PS2 supports progressive scan on the games, just DVD.
  6. Binternet
    Binternet
    Oct 30, 2004
    190
    Ok scap that, some games do support it. When the system is booting hold down triangle and x (i think) and you should get a screen asking if you want progessive scan. I dont think many games support this though. The manual should explain the procedure if it is supported.
