E
EdwinB
Hi all,
I am new to this forum and I hope you can help me with a problem I am experiencing.
My setup is as follows:
Panasonic 42PW5 plasma + PT600 tuner
Denon 2800 MK-2 dvd-player
I have connected the Denon using a component-video lead to the tuner.
When I play region 1 (NTSC) dvd's everything is fine, when I try to play a region 2 (PAL) dvd the screen goes black and displays "AV4C" (AV4 is used for the component lead).
When using a Scart (RGB) lead both NTSC and PAL are displayed fine.
I checked all settings on the Denon but everything is set correct. The player does support progressive for NTSC but when I set it to interlaced the problem is the same.
Has anyone experienced a similar problem with a Panasonic plasma or Denon dvd-player?
Any feedback is very much appreciated.
Thanks,
Edwin
Thanks,
Edwin
