Component Video Loop Through
Discussion in 'Blu-ray & DVD Players & Recorders' started by staffspeted, Jan 21, 2003.
  1. staffspeted
    staffspeted
    I currently have a Tosh SD520E DVD Player connected to my Tosh 32ZD26P via a component video cable leaving the 2 scarts on the DVD player unused.
    Is it possible therefore to loop another item (i.e a Sky Digibox) thru the DVD and into the TV using the component cable?
    i.e:-
    SKY > Scart out > DVD > Scart in > DVD > Component video cable > TV
    If so can I expect a true RGB picture from the Skybox?
    TV only has 1 RGB scart and I'd like this for my Multisat .
  2. AOD
    AOD
    Feb 7, 2001
    714
    London
    +5
    It's unlikely that this will give you what you want.
    The only equipment in your system that outputs a component signal is the DVD player, nothing else appears to. Connecting something to the DVD player with RGB will probably result in nothing being sent down the component connection. I doubt that your DVD player will convert from RGB to component.
    If I were you, I would connect your Multisat to the VCR SCART of your Sky Digibox and then connect the TV SCART from your digibox to your one RGB enabled SCART on the TV.
    I do something similar as I have a PS2 outputting RGB and my telly also only has one RGB enabled SCART.
    Actually mine is a little more complex as I have a VCR inbetween the Digibox and the PS2, but this has 2 SCARTs and can passthrough RGB (as long as I hit a button on the VCR remote first).
    In summary your connections would be something like:
    Multisat > RGB Scart Out > Sky Digibox (VCR Scart)
    Sky Digibox > TV Scart Out > TV RGB Scart
  3. whistlingDogg
    whistlingDogg
    Oct 14, 2002
    196
    Wokingham
    Not unless your dvd player can convert an rgb signal to a component signal... (Don't know of any that could do this)
