Component video connection cable problems
Discussion in 'Projectors, Screens & Video Processors' started by brian mcsweeney, Nov 8, 2004.
  1. brian mcsweeney
    brian mcsweeney
    I have recently purchased and LG RE44SZ21RD DLP tv and I'm reasonably happy with it so far.
    However, I do seem to have one problem which I can't seem to resolve and wonder if anyone could help or point me in the right direction.
    I've connected JVC component video cables from my my LG DVD/video recorder to my LG tv, but components 1 and 2 on the telly are saying they are not receiving any component signal and the DVD player is not recognised on the tv. I haven't got a clue as to where I may be going wrong.
    The cables are in their correct colour coded inputs and are securely positioned. I have no other SCART connections from the DVD player.
    Can anyone help?
  2. roym
    roym
    Sep 13, 2002
    67
    hi brian,
    check to see if the scart output of the dvd player is set to RGB, if it is select composite or s video as some dvd players cannot output component and RGB at the same time.
  3. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,522
    Kent
    +830
    Are you sending "component video" signal or have you just tried using a scart to phonos lead??? If so a scart to phonos lead only works where the scart socket of the source device is actually able to send out component video in the first instance (very rare - most send RGB).
  4. brian mcsweeney
    brian mcsweeney
    Thanks for your help guys. The DVD definitely has component video capabilities but in the DVD set up menu there doesn't seem to be an option to choose s-video, component or RGB. Any ideas where I can find this?
  5. roym
    roym
    Sep 13, 2002
    67
    unfortunatly brian i am not familier with LG menus, is there not a video or tv section in the menu this is where you would normaly find these options, if not then it would seem to be a hardware problem, could you not try a freinds dvd player or try your player on a freinds, just a thought :rolleyes:
  6. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    The option to select output is usually within the 'picture' menu. But looking at the service manual online for the LG DV6900( a DVD/VCR combo with component), it doesn't mention this which leads me to believe it auto selects the best output connected ( component in this case)
    Try checking the Special Menu and then the Main Input option. Select Component 1 and insure the cables are plugged into the row of component inputs on the left of the two sets on the rear.
  7. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    I meant on the TV for this bit !!!
  8. brian mcsweeney
    brian mcsweeney
    Fixed the problem, which I suppose I'm partly to blame for.
    Although I would put some of the blame onto LG and their rotten instruction manual which fails to tell you that at the back of the unit there is actually a tiny switch which gives you the option of RGB or Component. Switch it to component and hey presto!
    Surely it would have made much more sense and be a much more user-friendly option if this was available in the DVD's on-screen menu. Or am I just daft?
    Thanks for all your help everyone.
