Component video cables
Discussion in 'General TV Discussions Forum' started by Michael S Goodman, Dec 19, 2001.
  1. Michael S Goodman
    Michael S Goodman
    I have my 36ZP18p connected to a SD-210E DVD player through the component video cables supplies with the DVD player.
    Are their any better quality cables that can be used instead and if so, which ones would you suggest?
    I have sky digital connected to the TV through a QED RGB scart cable and IMO, that picture quality is superior to the picture quality from the DVD - the colours just seem brighter and stand out more.
    Any advice would be greatfully appreciated.
  2. Guest
    Try the PGV-332 component cable from the bandridge profi-gold series.
    Good Quality cable and you can pick one up for about £40-50 depending on where you buy.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    All you need is 75 ohm coax like RG59 or RG6. Proably 50p a meter. Then put on some good quality plugs or get someone like Keene / Lectropacks / Gordon knock up some proper RG 59 cable or the equivalent.
    If it is good enough for the BBC.......
  4. Michael S Goodman
    Michael S Goodman
    Thank you for the replies. I got a set of cable for £30 and the improvement is marked - the pictures from DVD are stunning. I love this TV!
  5. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Many people do but it seems trendy to knock it currently.:D
  6. Paulxflier
    Paulxflier
    Hi Michael,
    I've got the same TV & DVD as you and wondered what the cables
    were that you got in the end, did you get the PGV332 for Pds30.
    Looked at QED component video but seems studid spending Pds100 on cables
    when the DVD is only 145.
    Best Rgds / paul
  7. NeoBlade
    NeoBlade
    heh the Tosh ZP18 is a sweet TV when things work... When spiking, dark patches etc arise then things become annoying. Oddly enough only now my TV has slowly stopped spiking the image... Probably because it knows that it will be replaced with the new model ^_^
