I need a component video cable to reach a wall mounted plasma screen.Problem is that it will need to be over 3 meters.Does anyone know if such a cable is available and if so,which one would you recommend.
Many thanks,John Green
If you try the media factory at www.tmfsolutions.co.uk they stock VanDamme component cables at various lengths.
I use these cables with my plasma and the PQ is excellent.
Hope this info helps.
any set of leads with 75 ohm resistance or better will do the job there is a common rip off by sales guys that hi fi leads wond do the jon not true just get the best you can afford .
