component video + ATI RADEON 9000 PRO
Discussion in 'Desktop & Laptop Computers Forum' started by w8andc, Apr 21, 2003.
  1. w8andc
    w8andc
    Oct 25, 2002
    32
    11
    Belgium
    +5
    I want to use the best analog video output possible with my equipment. Component video ( Y Pb Pr) should deliver the best quality - better than S-video.
    My equipment:
    * PC with Hercules 3D Prophet 9000 Pro 128 MB (ATI Radeon 9000 Pro based graphics card)
    * Denon 3803 A/V receiver
    * Sony VPL-PX1 (XGA) projector
    My receiver has 2 component video inputs and 1 component video output and it also upconverts all video sources up to component video (Y Pb Pr).
    In the settings of my projector I can choose for INPUT A between RGB or COMPONENT. This Input A uses a 15 pins VGA female connector. SONY can sell a suitable cable (SMF-402) with on one side a VGA 15 pins male connector and on the other side 3 RCA component video connectors.
    Problem: I want to use the DVI-I output of my graphics card and connect it to the component video input of my receiver.
    1) Can I use the HDTV component video adapter from ATI?
    If so:
    a) Where can I buy this in Europe?
    b) Is there an easy not to costly way to order it from the USA?
    c) What is the meaning of those swithces on that adapter?
    d) How does those switches change the image? In other meanings: how does the video card knows that a different image must be sent?
    2) Can I alternative use cable number DVIRCA-5 (DVI-A to Component Video 3 RCA 5 Meters ) which can be bought on the following site:
    http://www.pacificcable.com/DVI.htm
    Can I find such a cable somewhere in Europe?
    3) Is there an other possibility?
    4) Question 1a or 1b for the SONY SMF-402 cable
    I would thank everybody who can help me with this.
    KRIS
    BELGIUM (europe)
    w8andc@pandora.be
  2. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    The very question ived asked in the past. You seem clued up on the ATI DVI to component converter but as you say its only available on the .com web site which only caters for the US and Canada.
    Sounds like its going to be a DIY jobbie.
  3. Kramer
    Kramer
    The ATI "dongle", as said is only available in the US. You'd have to have one sent to a friend/relation etc.. & have them forward it to you.
    That cable basically "breaks out" the component feed from the DVI connector. You may as well use the VGA connector on your graphics card for this - there's no benefit from DVI this way.
    The "dongle" switches change the resolution from 480p to 720p etc....
  4. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Ive got a DVI to VGA converter so all I need is a VGA to component and off I go.
    Wheres the best place for one of these then?
