Component via scart
Discussion in 'General TV Discussions Forum' started by Jbev, Dec 1, 2004.
  1. Jbev
    Jbev
    Aug 6, 2004
    140
    London
    +4
    I read recently, on the forums, that some scarts output component (the new Netgem STB springs to mind). Anyway, what am I looking for on the scart terminal that will tell me if it accecpts component through scart?
    The model no. of my telly is KV28FX66.
    Any help would be appricated.
  2. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    Are you sure that you're not confusing component with composite?
    Scart interfaces (such as the one on your FX66) are designed to handle RGB, S-video and composite. Only TVs with dedicated component input connections can handle that kind of video signal.
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, refer to page 22 of your manual. It confirms, as TVHeadache says, that your scart connectors work, when using 'component mode', with RGB. Regards, yt.
  4. jasi
    jasi
    Nov 28, 2004
    325
    London
    +4
    Actually, I have a cheap 17" LCD TV which accepts HDTV via the scart socket. I haven't seen that before though, I don't think its too common.
  5. jasi
    jasi
    Nov 28, 2004
    325
    London
    +4
    Sorry, and more to the point, it has the component markings pointing towards the scart socket, Y - Pb - Pr.
  6. cerebros
    cerebros
    Dec 27, 2002
    1,293
    48
    Leicester
    +29
    Incorrect. Certain Loewe CRT TV's can accept component input via SCART.
  7. TV Headache
    TV Headache
    Mar 3, 2004
    242
    16
    OK, I stand corrected on that point but Jbev, be assured that your the SCARTs on your FX66 (like 99% of TV scart sockets) does not handle Component, only the video formats defined in the CENELEC SCART standard...
