component - vga
Discussion in 'Cables & Switches' started by Ross82, Oct 26, 2005.
  1. Ross82
    Ross82
    May 3, 2005
    202
    +12
    Hi guys,
    Ive just been looking at the component to vga switch box i have and i think ive actually got the wrong one. Long story short ive been having trouble with colour when connecting my dvd player to PJ. After looking closer at the box
    Switch box
    It seems to convert a YPrPb signal to a RGB signal which my PJ accepts but seems to think its PC input and displays it in 4:3.
    After looking at this cable here:
    Component - vga breakout
    It seems this is the one i need as it dosent convert anything, just sends the same signal through different connectors (which again by PJ will accept a component signal/YPrPb though a d-sub/vga connection)
    Can someone here just confirm with me that the cable im looking at is sending a YPrPb - YPrPb signal but just using different connectors either end?
    Cheers folks, if this is right it has just saved my posting my PJ back to the manufacturer! (at a high cost!)
  2. Ross82
    Ross82
    May 3, 2005
    202
    +12
    no one?
