Component-Vga...is this possible...? any loss of quality?
ancient
Hi...Could someone please clarify...
I'm having my 32" Philips 32pf9976 lcd delivered soon...it has DVI (component through dvi) and VGA.
Now the DVI will be used at some point for HD.
So therefore I am only left with Rgb scarts and VGA.
I want to connect the dvd player through it's component.
Is it possible to connect component to vga...?...
ifso is the component signal true...or is there any loss of quality...?....+ where can I get this cable if it exists?
Thanks for any info.
R
Rob1698
It is not possible to have VGA and component at the same time with this set.
You will need a switchbox to do this.
(VGA is via an adapter to the DVI connector and component is via yet another adapter)
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
