Component to VGA - possible?
scumball
I have a modded Xbox outputting 720p from the official MS Hi-Def pack this component cable goes into a Panasonic AE700 Projector. I am getting another source with a Component output and so would like to utilise the VGA input on the projector. Can you get a simple (and cheap) YUV to VGA lead to carry 720p /1080i signals like one from here or do I have to go down the expensive JS route or X2VGA ?
LFCRules
Yep, you can go with the simple one, VGA on one end, 3 cables at the other. The only consideration is confirming your projector will accept a full component signal over VGA. If it does, no need for any conversion in between :smashin:
Andy
scumball
Any idea how would I find that out? It accepts a 1080i/720p signal over VGA from a PC....
