Component to VGA pin outs?
Redeye UK
Hello,
I've got a RGBHV to VGA cable and wondered if I could use the RGB conections for component to VGA on a panasonic panel.
It makes sense that they use the same pins (RGB=Pr,Pb,Y) but as TVs that are able to except component video via their VGA socket are pretty rare I'm having trouble finding any info on the net.
Thanks for reading.
Rob100
I'm 99% sure what you're saying is right. You can't do this on all Panny panels. I know you can on the 6 and 8 series.
If you want a dedicated cable I suggest you have a word with Joe Fernand (TMF).
Rob.
