component to vga/dvi questions
Discussion in 'Cables & Switches' started by sephy1024, Jun 26, 2005.
  1. sephy1024
    sephy1024
    I just got a Dual 26" lcd from Asda. and want to be able to use a component to vga or dvi cable/adapter box. I figure this will let me use component cables on ps2/xbox/cube for edtv/hdtv modes. Is this the way to go? I'm a bit of a n00b to the whole thing, and as i understand it I need a component capable vga, which as faer as i can tell via windows, it is.
    So will a (female)component to vga lead/adapter give me the results? And are they avaliable at low cost (i'm not demanding the very best picture possible via overpriced cables) Can anyone recommend suitable examples?
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    sephy1024
    That's about ten questions in two sentences :)
    Asking how to convert Standard and Higher Definition Analogue YUV signals to Analogue RGBHV (VGA) or Digital RGB (DVI) does not belong in the same sentence/paragraph as 'available at low cost' :) I fear the solution is possibly more costly than your new monitor.
    If your saying that your monitor has the ability to Input a range of YUV signals [480i(60), 480P(60), 576i(50), 576P(50) and 720P(60)] signals via its HD15 (VGA) Input then a decent quality 3RCA (F) to HD15(VGA) cable will cost you around £60.00.
    If you have to add in electronics to convert the Analogue YUV signals to Analogue RGBHV or Digital RGB then your looking at £200.00+ for the bits you require.
    Best regards
    Joe
  3. sephy1024
    sephy1024
    Thats more along the lines I was thinking rather then changing signal types (I assume thats what you meant)
  4. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,284
    The Borders
    +2,573
    sephy1024
    Its quite rare to find a Low Cost PC Monitor with an HD15 (VGA) or DVI-I Input that accepts YUV at the range of resolutions indicated - if you have then a 3RCA (Male or Female) to HD15(VGA) cable will be your lowest cost option.
    Our friends at VanDamme will manufacture the required cable for around £60.00 - we normally use/supply the Red Series Mini Four Core for lengths up to 10m.
    Best regards
    Joe
  5. DaveP
    DaveP
    Do you know for sure that the vga will take component input? Have you found a cheap cable yet?
    Dave
