Component to VGA Confusion
Discussion in 'Cables & Switches' started by Shakey_Jake33, Aug 24, 2005.
  1. Shakey_Jake33
    Shakey_Jake33
    Currently I'm using an VD-Z3 Component-to-VGA transcoder to hook up my GameCube/XBox to the DVI-I port on my LCD TV.
    However, I have stumbled across various Component-to-VGA cables to just plug the Component into the VGA native...
    http://www.beststuff.co.uk/specialist_rgb_leads.htm
    If I can do that, can I just dump the transcoder? I didn't think Component and VGA were compatible...
