Component To VGA Cable - Best Cable?
Discussion in 'Cables & Switches' started by carlosbrunos, Apr 15, 2005.
  1. carlosbrunos
    carlosbrunos
    I recently made a Component to VGA lead. I used an Ethernet lead (Foil Shielded), and some high quality gold plated RCA connectors.
    The lead works fine, except when I watch movies that have fast paced, dark action scenes in them (or with smoke). I get a ghosting. This doesnt happen with out door well lit action scenes. I have tested my projector using a VGA to VGA RGB cable and no problems.
    Should I retry using digital coxial thats silver plated? Also what is the difference in ohms rate mean? And one cable I looked at mentioned the mhz rating (300mhz).
    Also could the problems Im having, have anything to do with that the DVD's I try are all standard def dvds? not Hi-def?
    As a novice, any tips would be greatly appriecated.
    Carl :)
  2. mordzy
    mordzy
    Feb 7, 2005
    I had keene make me a Sync blaster cable .. RGB componant to VGA. it does have to be pluged in mind 9v adaptor. i guess this is the ghosting you see due to weak signal?
    have a look. although mine is fully wired scart to vga the signal is the same as what you are using.
  3. carlosbrunos
    carlosbrunos
    Well this is were I confused. Some people say RGB is different to Component, but both are Red Green Blue. errrr... well confusing. I've been told the main difference is that Scart requires sync pins.
    Carl
