component to scart rgb converter/cable
Discussion in 'Cables & Switches' started by bikes_monkey, Jul 19, 2005.
  1. bikes_monkey
    bikes_monkey
    hi
    i have a dvd player that has component out and rgb scart out. my tv has three scart inputs (2 with rgb)! should i try and use the rgb out from the dvd through a converter or cable into the scart or is rgb scart to rgb scart good enough?
  2. philipb
    philipb
    Mar 6, 2002
    1,986
    63
    Swindon
    +132
    chances are you won't see a diffrence between component converted to RGB and an all RGb feed. The latter may even be better without all the conversion steps.
  3. bikes_monkey
    bikes_monkey
    cheers philipb kinda thought that might be the case!
    cheers
