Component to Scart question
Discussion in 'Cables & Switches' started by RoobyRoo, Jan 13, 2005.
  1. RoobyRoo
    RoobyRoo
    Just registered on these forums, after having read through them extensively to help me upgrade to a new TV. I went for a 28PW8719 from Philips, 100Hz. So far I'm pleased with it.
    I previously had my DVD player hooked up with an S-Video to S-Video connection, PQ was fine on my old 4:3 21" set. I've now got a Thor Scart-Scart for DVD to TV, since the consensus seems to be that connecting to the RGB Scart gives a better picture. However, I've since read in my DVD instruction manual that the Scart socket isn't RGB-enabled.
    My DVD player has component outputs, so I was wondering will I see an improvement in quality if I decide to go for a component-Scart cable, such as this one :
    http://www.tvcables.co.uk/cgi-bin/tvcables/PGV372.html
    Any advice much appreciated. I don't want to buy another cable if it's not going to make much difference on a 28" screen size.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    This cable will not work with your TV.
    RGB an YUV component are different signal types and therefore YUV needs to be converted to RGBs to work. This cable does not do any conversion, it only passes the signal straight through.
    Mark.
