Component to scart cables
Discussion in 'Cables & Switches' started by lonestar, Oct 23, 2003.
  1. lonestar
    lonestar
    Jul 26, 2001
    182
    maghera, n.ireland
    +4
    Hello all,
    are these cables suitable for connecting sky+, dvd and video into an amplifier, they idea being that I will use a separate cable for each box, into separate channels in the amp.
    Hope this makes sense.
    Many thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    No Sky+ and VHS cant do componet RGB for Sky+ Composite for video what amp? waht display? etc
  3. lonestar
    lonestar
    Jul 26, 2001
    182
    maghera, n.ireland
    +4
    i'm probably looking for too simple a solution, but i was hoping that could employ a scart to component cable, along with the suitable audio cables, and connect my sky+, dvd and video (individually) into an amplifier, as yet undetermined, and then component output to a panasonic pt300 pj.
    After lots of reading, mostly here i'm more confused than ever. What a hobby (addiction) this home cinema is?
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    S-video is more suitable for Shy+ or RGB>YUV converter VHS has to be composite so you will need to run 2 or 3 cables to the PJ i reconmend running S-video to PJ anyway as it is ud=sed for amp OSD etc and consoles, Pc's etc.
