Component to RGB Scart
Discussion in 'General TV Discussions Forum' started by Robert, Jan 28, 2003.
  1. Robert
    Robert
    I would like to know if it possible to convert Component out to an RGB scar. Is their a sort of lead convertor or do i have to buy some sort of convertor switch box, that convert from Component to RGB.
  2. YellowCows
    YellowCows
    Dec 15, 2002
    141
    Have a look @
    Maplins ,
    Keene &
    Lektropacks
    They each have a component to RGB scart converter. I think it's the same part just re-branded for each, so I'd get the cheapest out of the lot.
    HTH
    Moory:)
  3. kerraig
    kerraig
    Just to clarify, is this component out to RGB scart in?
    Cos I need one too.
    Edit: I had a look at all these 3 sites and couldn't find the lead.
    Forget all that, found the lead for £89.99
