Component to RGB scart?
Discussion in 'Blu-ray & DVD Players & Recorders' started by GPMCDERM, Nov 20, 2003.
  1. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Saw this cable mentioned on a thread lastweek but didn't say much about it.
    Have just bought a 32" Philips 6517 and am using a Sony 725D
    for me DVDs, problem is that when playing US flicks I'm getting
    a distortion at the top of the screen from the macrovision....
    not worth the cost of upgrading the player again as its off
    the market a good while and as far as I know macrovision is
    not on the component output as I've never seen it on my
    projector......just wondering it the component output is
    compatible with the RGB scrat on the TV using this cable.....
    Profigold PGV372 - Component to Scart....should be as I've
    never heard of a TV that takes component scart socket?
    Cheers...
    Ger
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    I believe Loewe TVs can accept component on a Scart socket but I don't think your Philips will. Just stick with your RGB.
    Steve
  3. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    RGB and YUV (Component) are not compatible.
  4. GPMCDERM
    GPMCDERM
    Dec 12, 2002
    109
    Ah well....thanks for the help
  5. Uncle Dicky
    Uncle Dicky
    That's right some Loewe's will accept component on their scart input, providing you select the appropriate option in the menu. Sync on green.
  6. Jamesdc
    Jamesdc
    Howdy, that was my thread a while back, I found what I was looking for, a RGB transcoder. Keenes, KDS and some other places have them, ive still yet to order one, but i'll get around to it (probably the one from Keens (Syncblaster RGB2c transcoder)
    and yes, Loewe's do take YUV scart (or at least my Xelos did)
