Component to RGB connection?
L
leesbriggs
Hi, I was thinking of going for the Sony DAV-S880. I believe it has Component video out. If I connect it to my Sony IDTV (KV32DX30), what would be better quality, using the Component out on the DVD to RGB on my TV with a cable like this:
http://www.qed.co.uk/cables/sqart/av29.html
Or connect it using the S-Video out on the DVD to S-Video in (via scart AV2) on the TV using a cable like this:
http://www.qed.co.uk/cables/sqart/av12.html
Any comments or suggestions would be appreciated.
Cheers.
lmccauley
Note that this cable does not perform conversion from YUV to RGB: "When using a YUV source ensure the TV has a YUV compatible Scart input."
I think you'll have to use this connection.
Cheers,
Liam
