Component to HDMI
Discussion in 'Televisions' started by Talivar, Jun 27, 2005.
  1. Talivar
    Talivar
    Jun 19, 2005
    32
    my prob is i just got a xbox with the hd component leads but my TV is a toshiba 27wl56 and has a HDMI input, is there any way i can connect these? maybe some converter.
    Thx in advance for any help.
  2. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    HDMI is a digital-only interface. The XBox is analogue output only.
    If your TV doesn't have component inputs, then you would need some kind of analogue->digital converter - which isn't going to be a cheap "tenner for a cable" solution.
    (Also don't be confused by DVI - which unlike HDMI can carry analogue and digital video in some flavours. HDMI is digital only)
  3. AML
    AML
    Jul 22, 2004
    4,988
    Tokyo
    +229
    Agree with SN here. HDMI is digital only and uses HDCP copy protection. Component is analog.
    Are u sure your display doesnt have a component input? Thats weird considering it has HDMI!
    Component is just as good as HDMI, only analog. It CAN handle higher resolutions like 480p or 720p.
  4. Talivar
    Talivar
    Jun 19, 2005
    32
    nope dosnt have the component input slots, has a vga slot tho and i think i read u can do component to vga ?
  5. Stephen Neal
    Stephen Neal
    Mar 29, 2003
    6,080
    +681
    Yep - VGA is analogue R,G,B,H,V, and component is analogue Y+S,Pr,Pb - and conversion between the two formats shouldn't involve a major quality drop. (The sync standards are different - VGA carries separate H+V syncs, Component uses mixed syncs summed carried on the Y signal - and you have to matrix the YPrPb to RGB).
    If the TV can cope with 720p or 1080i spec inputs via its VGA input (and isn't limited to 4:3 PC resolutions - like 800x600, 1024x768 etc.) then an analogue converter should do the trick.
  6. Dutch
    Dutch
    Dec 5, 2002
    2,562
    3
    North Yorkshire
    +257
  7. supermackem
    supermackem
    Feb 20, 2005
    2,060
    sunderland
    +71
    I have this tv and use my usa xbox on it. I use the vdigi vga adapter component to vga. Only thing is the tv will only take 480p over vga anything higher and you get a green picture.:(
  8. scumball
    scumball
    Jan 12, 2004
    6,209
    Harrow - London
    +410
  9. supermackem
    supermackem
    Feb 20, 2005
    2,060
    sunderland
    +71
    Yep tried that also leaves you with a green screen on 720p and 1080i. This seems to be a problem some people are finding yet toshibas nots so helpful help line said nope nothing wrong with the tv xbox and some other game station thingy isnt compatablie lmao. They really dont have a clue.
