Quantcast
Component to DVI-i adapter
A
ambilightkr
limblee
It might, but I did buy one, but couldn't work out which switches needed to be in the on/off positions. If you do find out please PM me, I could even test it out for you before you buy.
A
ambilightkr
Did you have the same problem as myself with regards to the 60 hz
limblee
No problems with 60Hz games (crackdown+gow)
How have you got it plugged at the mo? If composite
Still got Blank/Black Screen.....
Turn on 360 with controller.....
wait approx 60 seconds to load
then do this key sequence
RIGHT RIGHT RIGHT
A
A
DOWN DOWN
A
(for PAL-60 just A) or (for PAL-50 do DOWN A)
Hope this helps mate :thumbsup:
