Component to DVI adapter? Or duel component switch?
Discussion in 'Cables & Switches' started by CrackDown, Dec 20, 2006.
  1. CrackDown
    CrackDown
    May 25, 2003
    401
    +39
    I have a projector with component and DVI input on the back. My dvd player and xbox 360 are both component and want both of them going in, so basically I need a component to dvi adapter that i can plug my xbox into and (i have a dvi cable already) have a dvi cable going to the pj, or if there is a duel switch of some sort where both components go into it and i can change between the signals?
  2. CrackDown
    CrackDown
    May 25, 2003
    401
    +39
    Anyone?
  3. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    What projector is it??? We are not psychic...
  4. CrackDown
    CrackDown
    May 25, 2003
    401
    +39
    Hitachi TX100.
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
    Hello CrackDown
    You need more than a Switch to accomplish Analogue and Digital Source Input to a single Digital (DVI) Input socket.
    You require something to transcode the Analogue signal to a Digital format - usually you require a full blown VP (Video Processor) from the likes of DVDO, Lumagen or PMS.
    Gefen have a New 'low cost' unit (approx 300.00 GBP) on the way (scheduled for a Jan 07 release) that gives you two Analogue (Component) with Stereo audio plus two HDMI Inputs and Outputs everything as a single HDMI signal with inbuilt signal scaling - see http://www.gefen.com/kvm/product.jsp?prod_id=4174
    Best regards
    Joe
  6. CrackDown
    CrackDown
    May 25, 2003
    401
    +39
    Jeez, that's pretty expensive. Isn't there such a thing as dual component connections going into 1?
  7. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,935
    The Borders
    +3,576
