component to component: no picture
Discussion in 'Plasma TVs Forum' started by IronGiant, Sep 28, 2004.
  1. IronGiant
    IronGiant
    Jun 7, 2003
    63,943
    Oxford UK
    +41,772
    Ok, I have the Philips SACD DVD player and a Philips plasma, I hook up my shiny Profigold component connector switch the plasma to YPbPr and nothing happens. On the DVD player, selecting output RGB gives a blank screen and YUV gives a format unavailable messsage. Is there another setting I need to change? :confused:
  2. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    On my E95 dvd recorder I has to change the outputs to video or svhs with component. It doesn't seem to work with rgb :mad:
