Component to 15 PIN VGA
Discussion in 'Blu-ray & DVD Players & Recorders' started by Marcel99, Apr 3, 2003.
  1. Marcel99
    Marcel99
    Anyone out there know where I can get a cable or converter to hook my component out on DVD player to a 15PIN VGA connector on my Projector?
  2. Dutch
    Dutch
    Dec 5, 2002
    2,580
    3
    North Yorkshire
    +263
  3. Liam @ Prog AV
    Liam @ Prog AV
    Well-known Member AVForums Sponsor
    Oct 18, 2002
    8,498
    Kent
    +827
    As long as you are using a projector that specifically accepts Component video via the 15 pin sub-D then it's purely a 3 RCA (or BNC) to 15 pin sub-D cable that you require - any good cable supplier can do you one of those. Uses the same pin configuration as RGsB IIRC.
  4. Marcel99
    Marcel99
    Thanks for the tips, I've got the cable on order from convergent-av
    :p
