Component Switcher differences...?
Discussion in 'LCD & LED LCD TVs' started by neoglow, Jul 7, 2005.
  1. neoglow
    neoglow
    Nov 3, 2004
    92
    Hampshire, South UK
    Hey guys, just got a Sharp LC26GA3E panel and have (at the moment) 3 component sources to connect to the panel.
    A Gamecube, PS2 and DVD player.
    This may sound very lazy but I dont like changing cables all the time and I do find some cables become very tight around the panels' RCA sockets, and god forbid if I ever yanked the whole socket out altogether, I think I'd cry. So I'd rather leave a Component cable attached and have the 3 sources connected to a Switcher. Now I have seen two differnet types and wanted to know the differences, heres the two...
    http://www.zektor.com/hds4/index.html
    http://shop.nexnix.co.uk/Scart_Switchers.html (the 3rd one down - JS Technology Master Component Controller)
    The first seems like a digital processor type switcher that is a similar size to a DVD player, whilst the other just seems like a simple switch box the size of a Gamecube. Now sizes aside, what are the differences - besides the price?
    Would I really gain anything from buying the more expensive Zektor one?
    Thanks guys. M.
  2. Rob1698
    Rob1698
    I think the small box allows only two sources.
    But in general, the larger ones come with infrared remote control and/or some automatic switching, while such a small device only has a manual A/B selection switch. This one does have automatic switching.
    I have something similar to the "trilogy 1" on that page (but with another name badge). But that is for SCART (with RGB).
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Quite a few sound processors have component switching. May be time for an upgrade!
  4. neoglow
    neoglow
    Nov 3, 2004
    92
    Hampshire, South UK
    So in terms of signal quality difference there wouldnt be alot??? I'm not looking for a really expensive peice of kit if a more simple auto-switching box like the JS Technology Master Component Controller would do the job no problem?
    M.
  5. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    I use the JVC JX-S111 available at www.svideo.com. It's about $70-80 (remember how favorable the current exchange rate is).
  6. neil c
    neil c
    Mar 25, 2005
    537
    +3
